Hello everyone. I’ve got a Formlabs 4L printer and I’m planning on printing various Platonic solid forms for my students to use for drawing purposes. I’ll be making cones, cubes, cylinders, spheres, dodecahedrons, and possibly extruded hexagons/pentagons as well.
As they’ll use these items for sketching exercises, I want them to be done in white resin (got a Formlabs V5 white jug awaiting), and ideally nesting capable so that I can store them in a smaller space when not in use.
I’d like to use as thin of a wall as possible, both to save resin material, but to also allow for nesting on some of the forms, such as the cylinders, cubes, boxes, extrusions- and realize I can’t nest the spheres or the polyhedrons.
I plan on removing the bottoms of each items before I make my STL files, so that I can drain all the items when printing (yeah, my spheres will have to have a flat spot on them for the drainage hole, unfortunately…unless I print half-spheres and glue them together- though I do not want any kind of construction glue line on the final product that might compromise the purity of the final objects.
I need, ideally, six sets of each object type (six tables in the room to arrange the compositions on for students to use and work around), and I’d like to make sure they nest together well, are durable, but of reasonable size.
So, I’m leaning towards a 1mm wall thickness for all objects, with a 1mm space between it and the next size of nesting object.
Suggestions/Opinions/Thoughts?
