Andrew, have you reached out to our support team? Preform crashes are definitely something we’d like to know about (and work with you to debug).
Is it possible to move generate supports? Id like to move them away from the edges of sharp corners, and inset them (to avoid pitting when removing them, sometimes a clipped support takes away a small piece from the model if too near a sharp, thin edge).
If one can move supports, I haven’t found how. If you can’t, please note that this feature, along with deletion would allow for automatic support creation + editing to mimic manual support placement.
Thank you.
Anton, thanks for the suggestions! We are constantly trying to improve and will keep this in mind.
Hi,
Suppose When we add supports of ring in preform…preform creats base along whole of the diametre of ring…and boundries of the base more thik than cntre of the base…thats all of the facts make wastage of the resin.
In preform some feature shuold be add
Below are the points…
1:base thikness should be down to 0.5mm even boundries of the base also.
2:boundries of the base not should be thik than 0.5mm also
3:base only creats where the pillars are builed not beneath of the whole model.
4:pillars angle should move through mouse like in b9c.
5:diameter of pillars should be decrease or change.
6:angle of the touch point of supports should be change.
7:diameter of pillars from base side should be decrease or increase
