Form 3 vs Studio 1
I’m currently a light user of a Form 3 and am very tempted to replace it with a Studio 1. My use case is printing small parts for railway modelling. The low cost of the consumables is what attracts me to the Studio 1. Anyone got any thoughts to share about the potential move to the Studio 1, especially any pitfalls?
Form Studio 1 should, on paper, be almost perfect for your use case. It uses a lot of the same underlying concepts as the Form 4 ecosystem, while also introducing some improvements, particularly around reducing peel forces (needs user testing for verification).
Coming from a Form 3, I can see quite a few positives in moving to the Studio 1:
  • Longer tank life — as a Form 3 owner, this alone should be a relief. :slightly_smiling_face:
  • Better protection of the optical engine from resin spills.
  • Larger build area.
  • Faster print times.
  • Cheaper resins compared with both the Form 3 and Form 4.
  • Cheaper consumables compared with the Form 3 and Form 4.
  • Skin-safe validated resins.
  • Certified safety options, particularly when using Alpha Resin together with the VOC extractor.
  • Open Material Mode.
  • With anti-aliasing, you should also see smoother print surfaces.
  • A 3-year service warranty is available, which means you should have some protection against product discontinuation for at least three years.
At this point, we simply don’t have enough independent real-world data. The printer is extremely new, while manufacturer testing and youtube reviews are useful, nothing replaces a few hundred users putting thousands of print hours onto the machines.
A few things I would keep an eye on:
Replacement prices for essential spare parts, particularly the LPU, BLU, and Motherboard. These are usually some of the most expensive components to replace and can really hurt your pocket — at least that has been the case in the Form 3 and Form 4 ecosystem.
As of now, I don’t believe the replacement prices for these parts have been revealed.
BLU and motherboard replacements should be rare and would normally fall under failure-related maintenance rather than regular consumable replacement.
The LPU is also effectively a consumable, its lifetime is calculated based on fluence, or total exposure dosage. So depending on the resin, exposure time, and the settings required for a particular material, the LPU will eventually need to be replaced. For the Form 4, Formlabs has mentioned a minimum LPU lifetime of around one year. I am currently unsure whether the same figure applies unchanged to the Studio 1.
I would also check the replacement cost of the filter for the VOC extractor if you are planning to invest in that option.
Hope this helps :smiley:
Thanks. Something else that’s new to me - it seems that the Alpha resins don’t need heat curing. Something confirmed by Formlabs answering a query of mine. So I’ve ordered a machine…..
