I am seeking out tips and tricks to get the best result for this resin, tic 50 A, we have results with sticky like finishigs even after curing, i’m currently polishing with forzen parts with sanding paper, does anyone know any other trick?
Make sure you’re washing with clean IPA, and cure the parts under water or glycerin. If they’re still sticky, I’ve had good results wiping down the surface with some mineral oil, or baby powder (one or the other, not both)
Thank you for your quick response! i did clean it with IPA, i cured it in the form cure L, but i dont quite i¿understand curing the parts under water or glycerin? what do you recommend on that ?
place it in a bowl of water and cure it in the cure l it will remove the tack
As others have said, cure it in a bowl or jar of water. You can also drop touch points down smaller but at higher density so they don’t leave as much behind.
