This has likely been mentioned before, but for how much this printer costs, it’s a feasible feature to add in to the Form 2+ or 3 or whatever the next gen will be.
What I am requesting:
- The addition of a camera for mounting within the enclosure to monitor the print progression. This would be a camera that you could adjust over time or even just a fixed mounted camera to check on your print while you’re away. I would love to be able to check on a 5+ hour print on the dashboard by looking at a picture or video from within the enclosure.
- The ability to cancel your print from the online dashboard if the print is clearly and obviously failing
Reasons to do this:
- Reduce waste of a rather expensive resin/material
- Reduce the amount of crap you’d have to clean out of your tank if the print fails
Just a thought. Anyone else want this?
