How is the SLA "expectation vs reality" compared to FFF/FDM?
My Da Vinci (with S3D software) can be set to 10 micron. Does that make it better than the Form1+? Layer height is not the only thing that affects resolution. For starters, the Form1+ prints using about a 1000 micron circle (Proof here). The Form1 was smaller we believe. And I would be willing to bet that $2000 FFF printer Monger mentioned is better built than anything you or me have ever seen, so I believe it can be incredible.
And believe me, sanding is a reality of the Form1+. Check out Ante’s pictures and then tell me sanding is not real. Then on his re-print he also got 1mm errors.
And don’t expect to print anything much bigger than a ring on the 25 micron setting. That is a common beginner mistake. You asked about expectations vs reality.
