Since I’m still waiting on a printer of my own, I entertain myself by looking at the high res pictures that Bunnie Huang took of the Form1 during his tear-down. On one of them I noticed a part that I recognized-- it happens to be the OLED display on the front.
Anyway, on Bunnie’s machine the display looks like a Newhaven Display P/N NHD-2.23-12832UCB3. So if you happen to want a spare for some day down the road (OLEDs are subject to burn-in over time)–
http://www.newhavendisplay.com/nhd22312832ucb3-p-3536.html
…should be the same blue display. You may or may not have to solder a new 0.1" header strip to it-- I couldn’t quite tell what the connection system was from Bunnie’s photo. There’s an converter PCB from Formlabs there to connect it to a ribbon cable, but I couldn’t tell if there was a socket on that or if it was directly soldered to the OLED.
If you’re more in to modding things to give them a more personal touch, this display is *probably* a drop-in compatible and just yellow instead of blue:
http://www.newhavendisplay.com/nhd22312832ucy3-p-3787.html
No guarantees that’d work, YMMV, opening the case probably voids your warranty, etc.
-Clay
