I am looking at using Elastic resin with my Form3 to produce some flexible parts for a robot character maquette where his arms and legs are an opaque medium gray “corrugated rubber hose” so that he can be posed. I’d like these parts to be the proper color, if possible. Can I use the Color Kit to tint Elastic resin for this job?
At least for the Flexible 80A that works according to the “soft tissue”-guide (it alters its properties tho), so it doesn’t seem to exclusively work with the color base resin but also with other materials. I guess you should be able to achieve most colors by using a total of 40ml instead of 100ml from the color-kit manual.
