Ability to disable supports as a 'view' option
All you have to do is click the EDIT supports button.
It will take a few minutes- but it will turn OFF your supports ( without deleting them ) and show you a grayed model that shows all the support contact points, without the supports in the way- and it will retain the red and yellow shading denoting minima and cups.
Use the layer slider to inspect layer by layer and make it easier to see the inside of hollow models.
