OK, thanks Evan.
It turns out that the laser flare happens to be mostly aligned in ether front / back or left /right so the 45 deg would interferer with seeing what is going on.
Mine is not to the front or back. It is diagonal.
I assume you have printed the crosses at a 45 degree angle then? Would make a lot of sense.
@EvanFoss, I believe you still have the model of the cilinder with the double helix. Do you mind send me that model to see what happens there? It seems that the laser really only has an effect on very tall prints (obviously). I’d like to see what happens on that cilindrical model that’s only a few cm’s tall.
Thanks
@Alex_Vermeer one last clutch at straws diagnosing your bubbling issue - how much resin do you put in the vat for printing? You should fill it to the max to avoid bubbling - so that as much as possible - the part printing surface does not lift above the surface of the resin into the air during peel.
@KevinHolmes, I fill it up to the fill line. The part definitely does not lift above the surface during the peeling process. Thanks for the advice though.
@Alex_Vermeer - well looks like there’s definitely something else at work - I presume you’ve opened a ticket? keep us appraised of progress?
Yes @KevinHolmes, I have opened a ticket and keep you all informed on the progress or possible solution!
My apologies. @RocusHalbasch. I’d like to ask you the same question then
Thanks
@KevinHolmes & @RocusHalbasch I kind of think we should start a thread just for posting files people use to test the corner cases on the printers and not photos of the prints them selves. I would do it but this is not my handy work.
That’s a great idea @EvanFoss, except I think that any new thread are automatically closed after 15 days. Perhaps @Sam_Jacoby could override that for something like this.
If not, I would be happy to set something up on YouMagine that we could all link or point people to to??
Remember when things are posted to label what they are a test of. I imagine as the thread grows it will include stuff to test other issues.
I agree @EvanFoss and @Steve_Johnstone,
This is something I mentioned already in the ideas topic @Sam_Jacoby posted: Forum Ideas?
Hopefully it’s something we can achieve!
As for a thread for just these that would be great but I don’t think we could keep it clean.
Probably not. Ideally it would be more of a table-of-contents with one post per test and a link to an in-depth thread.
could always stick them on the wiki - I just kinda let it slide while I was waiting for my F1+
in any case here’s the original tall crosses file - and yes @ChristopherBarr as @EvanFoss suggests, they were created specifically to highlight issues from flare - namely flaking and solid surface corrugations. tall_thin_calibration_30mm_cross.STL (770.2 KB)
Here’s a slightly different one - thin_calibration_30mm_cross.STL (838.2 KB) only 60mm tall, height is important in showing up issues with flaking - but it probably doesn’t need to be 80mm tall like the original. Also I made it a bit wider because that should actually make issues more obvious. Haven’t tried this one though.
To use them - just put x rotation to 180 before generating supports.
Maybe a picturebook webpage? You could look through one of everything and decide which most looks like your failed print. Then click it for an explanation and a test print.
I started a separate thread for that under feature requests. But it isn’t necessarily a request to FormLabs.
