[Preform] Multiple selections with CTRL+click
Hi there,
This has been suggested back in 2013 (another one here )
We can select multiple bodies by click and drag but if for example I want to re-generate supports for multiple parts that are not all in the same area then the click and drag method doesn’t work.
It would be useful to be able to CTRL+click to select multiple parts.
You should be able to select multiple bodies with Shift + Click.
Try it out and let us know if this works for you!
Hello Matt, thanks for the he answer. I will definitely try that, I’m guessing shift + click is a standard shortcut in some software… I have always ever seen ctrl+click however, as shift+click is usually used for continuous range selection.
Cheers !
John
