Had a print out of castable wax that was really hard to get off a while ago. This was as much as I could clean it - I’ve tried IPA, the included tools, even sandpaper to get this residue off, and at this point there’s barely any and it’s completely flush with the bed but there’s still some left. Now I want to use some normal grey resin with the same bed. Is this clean enough to not cause problems? If not, how do I get rid of the rest of this resin? Here’s the pictures.
I think you are probably OK. As long as the stuff in the upper right hand of the picture is not too thick then I would print with that build plate. I would just orientate the print so it avoids that corner as much as possible.
That won’t be a problem.
