C/P from the same question on another thread:
I’m not a big poster but thought I’d add something. I’m the lead AME for a $12B engineering company and our Health & Safety Engineering team is extremely stringent on chemicals and safety. A full panel chem review was conducted on our print lab which runs a multitude of printers 24/7 producing thousands of parts a year; this included a 24 hour test of chemical/vapor emissions, a noise study, and an in depth analysis on every MSDS sheet on every Formlabs resin. With every printer in our lab running everything was given the full go ahead with no fume hoods or vapor extraction required. Just a normal room with A/C and no opening windows.
If that HSE team certified it to acceptable standards I’d imagine your personal Form 2’s or 3’s will be just fine.
EDIT: I should also add that the only PPE that was required based on this assessment are gloves for handling tanks/cartridges/IPA soaked parts and goggles when we make custom Formlabs resin blends in our mixing room (Last week we made a translucent red that glows in the dark with properties simulating ABS).
EDIT 2: For the sake of thoroughness I should also add that the only fume extraction requirement we have in the print labs is a fume hood over our IPA stations but that requirements exists company wide anywhere IPA is used. That is not tied to the Form Wash being unsafe just that IPA in general is a chemical that we required fume extraction for.
