Tough 1500V2 vs Tough 2000V2
Hi -
I was hoping someone have some advice on Tough 2000 vs Tough 1500. As much as I like Tough 1500, it is problematic at best in terms of warping as the parts I print Arte mostly large, thin-ish flat areas for enclosures or brackets.
Is Tough 2000 maybe less prone to warping during curing?
Regards, Friedl.
In my experience with both, Tough2000v2 seems much better “behaved” than Tough1500v2. I had immediate print failures with 1500v2 due to much higher peel forces than any other material I’ve worked with (i.e. sounded like velcro being ripped apart, much more than any other print I’ve run). Warping and dimensional accuracy did seem to be more of a problem as well (judging from assembling mating halves of the housing that was printed for that job) FYI, /somewhat related: comparing Tough2000v2 vs Tough2000v1.1: dimensional accuracy and print speeds are notably better with v2
Hi @Paul_Cilino
Thank you for your feedback!
I have no failures during print, but also noticed the noise. At some stage I was worries the film would damage. My main issue is severe warping during curing, even curing with no heat (35C) ends up with thinner walls and flat surfaces (1.5mm - 2mm) warping after a while. This is very noticeable in my case as I have PCBs with buttons and connectors that need to be accessible from the outside, to tolerances are small.
I guess Rigid resins would be better like Rigid 4000 or Rigid 10000 but they are just too expensive locally. Tough resins are still quite expensive but not nearly as much as the rigid series. Standard resin is just too brittle.
I would say, compared to either Rigid4k or Rigid10k, Tough2000v2 could be a good, “balanced” option which would:
  1. avoid specialized solvents/washing requirements
  2. help keep costs down
  3. still allow for self-tapping screws, which could be needed in a typical case with a PCB
  4. give you a robust enclosure that wouldn’t be so brittle that it might break if it were dropped.
I admit, all of that is probably very presumptuous on my part, without specific details for the application, but again: I experienced a lot less difficulty processing 2000v2 compared to 1500v2.
I will get some for sure thanks! I did not even consider specialized cleaning solvents for rigid materials, thank you for the heads up. I use IPA at the moment.
I did print some brackets with Tough 1500 V2 and they came out really well. But they are stocky solid parts, so less prone to warping. Enclosures are what I print mostly and at this stage I have given up on printing anything going to clients, just mostly print to test form and function and then send prints of to be printing using SLS rather.
I will order some Tough 2000 Monday and will do some prints as soon as I get it. I will let you know how it goes. Shame I have two liters of Tough 1500 left, haha
How flat? I’ve Been having issues with accuracy of Tough1500 for any thin parts or geometry. I do enjoy it’s consumer-end plastic levels of durability and finish. I think Tough2000 would be great for your enclosure, I haven’t had any problems printing with it yet.
And be wary of the rigid series for your use-case. Rigid10k especially is very beautiful yet brittle material.
Hi @KristianBansil
I am taking about completely flat parts with perpendicular sides, like a box. you ca see this thread, I have been fighting this a lot but without any real success. Printing directly (and perpendicular to) on the platform gives the best results, printing flat on it, the worse it seems.
I can understand the rigid materials are brittle due to the “stiffness” but are they weak like the standard resins? So do they break easily when eg. dropped?
Many Thanks!
Friedl
Tough 2000 warps less because it’s inherently stiffer, so yes it would help. I generally prefer T2000 for most things. T1500 has had some weird quirks for me…most recently a few parts have continuously shrunk after post curing which is very odd and T2000 does not exhibit that.
In terms of warping…sometimes depending on part geometry and orientation it’s inevitable. A poorly socialized and known contribution to warping, which I’ve posted about before, is to ensure you parts are dry. This is not compressed air dry, or dry from sitting out for a few hours, I mean dehydrated to expel all absorbed IPA.
I dehydrate all Tough resins at 35C for 3 hours before post curing and it helps a lot.
If that doesn’t work then either curing with the heater off (off entirely, not a lower temp) can help or you just have to find a way to fixture the part during cure to prevent warp.
Hi @leonhart88
I will try Tough2000 then for sure. Even though I have given up on trying to print even small batch parts (not that it cannot be done as I have seen you work, I just do not have to capacity to put in such care) it would still be good to print more accurate prototypes before sending it off for printing.
Thanks for the drying tip. I do let parts dry for a long time, sometimes overnight, but I I have never thought to let it dry at 35C.
There have been instances I’ve seen where leaving parts out for 12+ hours still isn’t enough, so I do highly recommend an actual dehydrator.
Just printed more parts in Tough 1500 v2 today. For me personally I will not use it for parts that are part of an assembly going forward. Even though the parts look ok-ish after print, once mating them with eg. CNC’s parts, it is evident that there was some warping.
In an attempt to dry them out… I left them out for couple of hours, then used a high speed blower and then cured them at 35C for 30mins. After this I did a full cure as per the Form Cure profile
I will try the Tough 2000 this week.
Thanks again for the feedback!
