Did my very first print with Black V4 (my previous experiences have been with V1 and V2) and i’ve noticed some things…
Now, first of all, the print came out beatifully. No issues whatsoever, and, unless you tilt it just so that the anisotropy of the layers shows up as texture, for all the world, it looks like an injection molded part.
That said, i’ve noticed that some supports are flexible, while some supports are super brittle. I had a few snap like a twig, into multiple segments, just from the force of cutting with an xacto knife. And other i’ve bent back and forth with no problem, and they wouldn’t break. This is all post-cure, mind you.
I’ve also noticed that, if you look very closely (so closely that i’d need a very high magnification macro shot to show it), you can see tiny dots on the surface, in places, that appear to be clumps of pigment. There’s no rhyme or reason to where they show up - just random places on the object. Some parts don’t have a single one, some will have multiple. They’re not printing artifacts, they look like someone sprinkled fine black powder on the print, and in some places, a speck or two stuck. Super tiny things.
With both of these things in mind, i think the issues people are having with Black V3/4 is due to it being way way less homogenous than the old blacks. Both the photoactivator and the pigment do not mix 100% well, even with agitation of the cartridge before printing, plus, the V3/V4’s surface tension appears to cause additional issues with the pigment (clumping).
I’ve got no solid proof for this, just a gut feeling.
This does kinda jive with the fact that V3/V4 is:
- way more viscous than the V1/V2, and
- both new grey and new black bubble more
