Hello to all
I have a bad tank noise when you move to the right.
This noise begins to feel like it after about 7 hours of work and gradually gets more and more.
It’s like a snap that something comes off
Do you also have the same problem?
Thank you
If you’re able, uploading a video is always a big help for issues like this. You might also upload the .form file that’s causing trouble. Sometimes, if a part is being overcompressed into the PDMS, there will be a bit of ‘knocking’ as the printer tries to peel but this often occurs earlier in the print and corrects itself as the print continues.
