A few months back I noticed an update to the Dental Model V2 support system which makes it very difficult to remove supports from the prints. It can take me hours sometimes, whereas I used to just be able to pop a majority of my prints off the supports in 2 minutes. Did anyone else notice a similar increase in difficulty? Should I simply reduce the connection diameter to achieve the easy remove properties from before? I think they made the connections longer…
Hi @RyanAx365,
Thank you for bringing this up. Although I’m not sure regarding a particular update to Model V2 Resin support settings, you could definitely reduce the touchpoint size to make supports easier to remove. The length of the supports themselves, along with other properties, can be edited as well: see Editing Advanced Settings for supports in PreForm.
