What all would anybody want to know. Basic info from Formlabs and people is cool but I really want users who have done it to speak on it.
I am assuming hand pouring resin in to a dedicated 80 dollar tray. Perhaps would have to be a specific type of tray for a “tough” resin???
Curious on everything else. The preform stuff. How the printer is
and then a big one is success rate. A top reason I even care about the brand “Formlabs” is because of very low failures while my friends with cheap printers always complaining about another night of fails. If the Studio 1 is just like a Phrozen in that case then meh. But if its like all the 30-50 cheap tough resins with atleast -most- the stability of Formlabs this could be a great move for me and what I’ve been doin’.
@revel At this point, everyone is curious about everything you’ve mentioned—and a whole lot more.
On one hand, we’re still waiting for the official response, which has been long overdue. On the other, we’re waiting for early adopters of Studio One to start filling in the gaps, but that looks like it could still be more than 40 days away.
I did watch a couple of Studio One review/promotional videos on YouTube where the content creators appeared to use third-party resins. Maybe you could check those out as well.
I’ve been beta testing the Studio 1 for a while now and have spent a good amount of time tuning custom materials on it, so I’m happy to share what I’ve seen.
The printer itself
The new LPU puts out less power (mW) than the Form 4, but the light structuring is noticeably better. I started on Formlabs systems, so I may be a little biased, but I find their material tuning process simpler than on other cost-competitive mSLA printers. If you’re coming from another platform, my advice is to set aside most of what you’ve learned there and approach it fresh.
Tuning workflow
Start with the Formlabs resin closest to your application. I focus on what the part needs to do, since each base profile (e.g., Model vs. Tough 1500) has different finish and mechanical characteristics.
In PreForm, use the Settings Editor to create a new profile with Open Material Mode (OMM) enabled.
Print a tuning part. I use a custom one that makes the process easier. The hardest things to dial in are usually first-layer squish and parts with a lot of cupping features.
Once the first revision is finalized, back up the profile and document the settings. I keep mine in a spreadsheet.
Tank
Yes, I’d recommend spending the extra money on the Pro resin tank. For me it’s the highlight of the system. I don’t spend time cleaning tanks, replacing film, or wondering whether new film has shifted my parameters, so I can focus on tuning. It also means I can run critical parts on the same machine I was tuning minutes earlier without cleaning out the tank.
Filling and mixing
In OMM you hand-pour resin into the tank. It’s a bit of a hassle, but I do the same on the Form 4 so it isn’t a big deal. Once your settings are solid for production, you can also refill cleaned, used cartridges for automated dispensing.
The one thing I miss is the Form 4’s mixer. On the Studio 1 I mix manually in the tank with a printed spatula. Mixing with the build platform alone hasn’t been consistent enough for me, especially with highly filled composite resins where particulates settle. For those I had to increase the phosphate-ester dispersant (Disperbyk-111 class) to 1.5%. A low-fill resin like RPG shouldn’t need that, but I’d still give it a good manual stir before each print.
Reliability
With Formlabs resins, I’ve had one failure through the whole beta: a support didn’t fully print, and the part didn’t need support there anyway, so it came out fine.
Hope this helps, and feel free to ask if you have more specific questions.
