All the marketing/support/tech materials I managed to find mention that the Studio 1 has a heated resin tank with a temperature setting of up to 45ºC. None of those materials mention any Open Material-related restrictions.
However, looking in PreForm (latest release, as well as insider preview versions) the Studio 1 Open Material flow is slightly different (you copy a special “Open Material” profile instead of one of the FormLabs resins), and in that new flow the heater setting is just a binary toggle whether to keep it at 25ºC.
Hopefully, FormLabs can clarify whether it is an intended limitation of Studio 1 or just the software not being fully ready.
Interesting — if this is an intentional limitation, it could make printing with anything beyond officially supported resins impractical provided the resins require heat for printing. For example, compatible Form Engineering Resins default to around 35°C on the Form 4, so a fixed 25°C limit could prevent them from being used under their intended print conditions.
That said, without data on how temperature actually affects the material properties or print performance of these resins, there is still some grey area.
But purely from the UI, it does look like a limitation.
Well, I’m pretty sure it will heat the official resins to their optimal temperatures (up to 45ºC as advertised). The issue concerns 3rd-party viscous resins, like Siraya Tech Blu Lava Black – that one is difficult to print at 25ºC and is easily printable at 35ºC.
To me, allowing to heat 3P resins vs not is a buy vs no-buy decision. I wonder what people who already preordered think.
I have tagged this under “Support & Troubleshooting” as the chances for technical support is better. Someone from the Formlabs team should be able to resolve this query for you
Hi @Sophia_M. I should say that’s an extremely important thing that is not mentioned anywhere in the documentation or marketing materials, not even a single time. I would be surprised if most of those who pre-ordered did not expect to be able to heat 3rd-party engineering resins up to 45ºC.
I’m pretty frustrated by this. Not cancel my order frustrated, but pretty annoyed about the arbitrary lock down. Realistically there aren’t a lot of 3rd party resins I would need if the alpha resins are as good as they look on paper, but blu lava black is one of my favorites on my current S4u16k. The marketing specifically says “you have complete freedom to print with any resin” (emphasis mine) and “Resin heating to 45°C” without any caveats. Not to mention a lot (most?) of the “compatible” formlabs materials are printed at 35°C or higher on the 4 series, and I don’t see how that will work if we can’t set a temp other than 25°C especially with how viscous some of them are.
I might be shooting in the dark here, and I genuinely hope I’m wrong, but I wouldn’t be surprised if Formlabs eventually introduced a paid tier of PreForm for Studio 1 users who want access to more advanced print settings and greater control over Open Material Mode.
Every business model ultimately has to answer one question: How do you retain customers and generate recurring revenue?
If you sell a capable, economical, open, and durable machine, customers have fewer reasons to keep spending money with you. The most predictable recurring purchases would be replacement or maintenance parts, such as the LPU, resin tanks, and build platforms. But these aren’t necessarily frequent purchases, nor would you want them to be. If customers have to replace components too often, it reflects poorly on the product’s reliability.
Resin sales are another potential revenue stream, but an open-material ecosystem doesn’t guarantee that customers will continue buying proprietary resins, unlike the more controlled ecosystem surrounding the Form 4.
Service plans are another potential source of recurring revenue, but since they’re optional rather than mandatory, there’s no guarantee that every customer will subscribe or renew.
That leaves the slicer as a particularly attractive opportunity for recurring revenue. Software is one of the few ways a company can maintain a long-term commercial relationship with its customers, which is probably one reason so many companies are moving toward SaaS and subscription-based models.
