Hello friend, I have the problem for realization the simple ring,
Gonna need a bit more info to be able to help out. The model itself would be handy, what you did or didn’t do, the preform file to show the orientation of the part etc.
So it prints fine with the white resin but not the tough?
Are you using the latest version of perform and updated your printers firmware?
Also, it looks like you are using Tough resin. If you are trying to cast this ring, you probably want to use Castable resin.
