Reusable mold material
I have used remelt from Alumilte but came across the same thing probably from the manufacturer called composimold found here:
http://composimoldstore.com
They also have a putty but I haven’t given that a shot yet. One note try not to overheat it or it will bubble. The cooldown is pretty slow so you can degas it in a standard vacuum chamber if needed.
I find it handy for banging out extra copies of parts in various urethanes or even silicones since neither stick to the mold material. I still give the mold a quick hit of a release like the manns 200.
Thanks! That Composimold material looks interesting.
It does have a low durometer, thinking in the 20-30 range. When cutting the part out you can chill the mold in a fridge to make it a little stiffer.
The cool down on it is slow so you have plenty of time to degas if you need to in a standard degassing chamber.
