Resin Tank Not Filling with white or black
Ok, Just got my new F2 and the resin tank will not fill. The slit is opening on the bottom when you push on the side but no resin is dispensing when inserted. The printer recognizes the cart but nothing. Changed from white to black cart. The slit on this on was sealed closed. But finally opened after pushing on the side. Same thing no resin. Looking in on the top with the cart removed I can see a lever that probably pushes on the rubber piece to cause it to open. But I cannot tell if it is functioning. The printer says ready to print. However no resin. Yes the vent cap is open.
Ok working fine now. Rebooted printer by unplugging and plugging in again and loading the file again to print.
