Reduce waste by multi part printing?
The support structures are basically waste right, does the software tell you how much resin the supports are using? When I get my printer I’d like to be able to waste less resin by experimenting with printing multi parts instead of single large prints with larger support structures.
The software shows the resin use estimate all the time.  Just note the number before you generate supports, then subtract that from the number after you generate them.
