Prints not sticking to build platform
been using these printers for almost 3 years, starting with the Form 3. Nothing has changed in our process. been using the Form 4L since it first came out
ok, here’s an update…replaced LPU unit again, also installed new BPU and Buildplate. releveled printer, aligned buildplate. Put in new tank and mixer, fresh new resin. started reprinting a part from history (that we’ve printed dozens of time)…still failing with adherence to build plate. Pretty sure management is about to instruct us too throw it in the dumpster
This is quite perplexing:
  1. Printer leveling: Could you independently verify whether the printer is mechanically level using a spirit level? I’m wondering if the printer’s built-in leveling sensor might be giving an incorrect reading.
  2. Print history vs. newly sliced files: You mentioned printing from the print history. Have all the failed prints so far been reprinted from history, or have you also experienced failures with newly sliced files?
  3. Firmware update: A new firmware version (1.16.1) was released for the Form 4L on June 18, 2026. Do you recall updating the firmware around that time? More importantly, can you confirm whether the printing issues started around the same period? Also is the firmware for 4L up to date?
Could be less probable:
can you check if the build plate arm connected to the Z axis has any movement or misalignment?
we always use a spirit level to verify that the printer is level
print fails with both newly sliced parts, or parts from history
no movement in build plate arm
both the preform and printer are on the latest updates
What does the part you’re trying to print actually look like and do you have pictures of the failure?
When was the last time you printed this correctly?
Are other parts also all failing like this?
All parts, not just one particular part
That’s wild - never seen anything like this before. I know you’ve tried a bunch of things already but just throwing out all these from my experience in case any of them help:
  • Could be contamination on the build plates? But sounds like you threw a brand new one on there. If it wasn’t new, even though you clean with IPA in between prints, I’d recommend scrubbing it with scotch brite or very rough sand paper (eg. 180 grit), clean thoroughly with acetone to get all the particles off, then clean and dry with IPA. Redo BP alignment.
  • Check to make sure there isn’t anything weird with your print settings and/or the early layer merge/compensation settings in the Preform support flyout. There are certain combinations of parameters that I’ve seen bugs with
  • Even though you replaced the LPU - it’s possible the LED backlight unit is failing or generating way less power than it’s supposed to. Have the support team check the power output numbers to see if it’s in good health. Sounds like you may have done this already though?
  • Maybe there’s something wrong with your Z axis.
Not sure if any of this helps - you’ve probably already tried a bunch of these. Good luck and if you ever figure it out, let us know :worried:
We have tried a bunch of these things. new build plate, new LPU, new Backlight unit, new resin tanks, fresh resin. No changes in print settings. Realigned Buildpate, Leveled printer, even went down the rabbit hole of trying different z-offsets.
Crazy.
Have you cleaned the lubricated the z axis ball screw? You could try manual motor moves, maybe you can see or hear an issue that way
