Print Quality Issue with Black Resin
#28
I appreciate all the optimism. Good to hear the journey w/ Form 2 was similar and ended well. There is certainly a lot to be impressed by in the Form 3, and it makes sense that the new tech should perform better when dialed in. The surface finish is quite remarkable, esp in clear resin.
I did that same print in .025 btw this this result. It’s pretty comparable to the .05 results I got earlier imo.
Imgur:
Not impressed with my Form 3 either. Apart from the issues highlighted about it is much noisier than my Form 2, a lot slower to both get ready to print and to actually print. Wish I had bought 2 more second hand Form 2’s rather than the Form 3 now.
BR
Rich
#30
@Komodo and @jbrownson,
Oh! The new version(3.1.2) of PreForm was released today.
  • Improved the 100 micron layer thickness setting for Grey Resin
  • Improved the 50 micron layer thickness setting for Dental Model Resin
  • Improved the 50 micron layer thickness setting for Tough Resin
  • Improved the 25 micron layer thickness setting for Color Resin
I am going to test the new grey resin setting.
JC
#31
This is a test before the recent PreForm update(v3.1.2).
All models are flat, not with an angled orientation. Flat layout seems better than angled.
Gaps parallel to the LPU movement direction are clearer.
#32
This is the result of the recent PreForm version 3.1.2.
It seems to get a little better than 3.1.1, but not enough for my expectation nor even close yet to the result from Form 2.
PreForm 3.1.2 (below), 0.1mm layer thickness
PreForm 3.1.1 (below)
Winner Winner Beta Tester! :crazy_face: Why do I keep doing this???
JC
#33
@Komodo,
Right! This obvious slower print time is due to the LPU movement, so it doesn’t seem able to be reduced a lot.
Also, much noisier due to fans and the LPU moving sound, but it doesn’t seem to be changed.
Therefore, it has to have some other outstanding merits.
O.K. The design is great, and I love its several new functions.
However, I hope the print quality at least can be remarkable after tuning up the resin settings.
JC
#34
I think that you’re correct that some of the slowness is due in part to the LPU movement, but I think that one other reason is the smaller laser dot.
The 85 micron dot is 40% smaller than the dot of the Form 2, so it stands t reason that the laser has to spend more time to fill in the same area as before.
So unless they figure out how to dramatically speed up the one galvo (X direction) and the LPU movement (Y direction) I don’t think you’ll see much improvement on the speed.
#36
It seems that given the stats of the Form3 that this is something that should be able to be fixed in a software update
#37
Here’s the test print on my Form 3 in White V4. I didn’t take a very good picture, but as you can see, the small holes are completely filled in and there is no gap between the shapes along the back.
#38
.1 or .05 resolution? I just did a .1 and it looks about the same as yours (hard to tell where yours filled in on the front though) but was going to do .05 based on results from above. Won’t run it if you did .05 though.
Form 2 below on left, Form 3 on right. 0.1 resolution. I think this demonstrates that my Form 2 need some maintenance more than the Form 3 being way better. My results are better than Joonghyun’s from post 17 above though (for Form 3).
#39
Thank you for your efforts at Formlabs. Nevertheless it is very disappointing to me that I’m used as a beta-tester when buying a newer machine that is supposed and announced to be much better than the old one.
#40
To those having issues with speed and noise, are you running the latest firmware (1.3.4)? We changed it to turn the fan off when the printer is idle and have been working hard to speed up print times.
https://support.formlabs.com/s/article/Firmware-Release-Notes
#41
@piGuy Your result looks almost the same as mine. Current software settings seem to be over-curing, such as strong laser power with slow scanning speed?
I doubt that the better surface quality which Formlabs has put up also can be affected by this over-curing.
Let’s wait for the next PreForm and Firmware.
JC
#42
@gjgomes
Your Form 3 result seems similar to mine too.
This quality can’t be accepted by my field. I am wasting my time and resins with this current print setting. Perhaps you all too.
Also, your Form 2 has some serious issues.
You would better check any contamination on the galvo mirrors and the main mirror. If you use a regular resin tank(not LT), the foggy silicone surface can cause the issue.
You should be better to contact Formlabs for further instruction for it.
JC
#43
@gtl
Thanks for the information.
Yes, I am. Unfortunately, it can’t solve this print quality issue. The fan off function during idle status is much better.
I am looking forward to any better result on the upcoming update of PreForm and firmware.
JC
#44
3,607 hrs on Form 2-1
4,093 hrs on Form 2-2
1,503 hrs on Form 3
7,763 hrs on previously retired Form 2 (interesting this is almost exactly the summed total of my two current Form 2’s)
#45
It should have all been done before the machine was released…now we are all guinea pigs for testing resin at $150/L with sup-par results. The management has not learned past lessons, and rushed this machine out to beat some competitors, likely…without bothering to get the settings right for the small subset of resins you can actually use on the Form. 3. If you haven’t bought a Form3 yet, I would wait. Especially if you have a Form2 that’s working. The Form3 is not ready for serious work yet.
#46
I submitted a support ticket concerning this issue and was told that the problem is software settings and it is being actively worked on. Hopefully this will be fixed soon.
#47
Printed some of mine, in grey, with latest fw and preform here:
#48
For anyone interested: I had a long and helpful conversation with a couple Formlabs employees late last week in regards to my Form 3 and 3L preorder. I highlighted this thread, along with @Ante_Vukorepa’s PoisedWhale reporting for duty and @TravisRogersprint with fine holes. I know Formlabs is working hard to tune print quality, but I think they could do more to make that effort visible in the forums. I suggested they reach out to you guys (along with others who are graciously volunteering their time, resin, equipment, etc. to produce all these test prints), work with you to recreate and diagnose the issues you’re seeing, and push out updates targeting improvements, with the ultimate goal of helping you achieve better results.
I’m a little nervous since based on what I’ve seen here, the Form 3 does not appear to be unequivocally better than a Form 2, and it looks like there may have been some regressions. I would like nothing better than to see you guys reprinting these tests on an updated Preform / firmware with perfect results. I asked them to HOLD my order in the meantime.
I don’t blame people who are frustrated; I agree the issues being encountered should have been detected and corrected before it shipped.
I do think it’s clear they invested a ton of improvement into the hardware platform in the Form 3 and I feel like it ought to be capable of exceeding what came before - I’m hopeful they can shake out the glitches, and I’m grateful to you guys for bearing through and churning out all those tests.
