This part continuously fails. The top surface doesn’t build. I think it could be due too a lack of support for that surface. We already tried different orientations but this one surface stays a problem.
I don’t know if you’ve tried more aggressive angles but that might be a good thing to try. Angling 45 degrees in what appears to be your y axis and somewhere between 20 and 30 degrees in your x axis might encourage more supports on that surface and make it easier to print.
Happy to take a look at the model and have a go at making a better behaved .form file if you’d like.
Yeah. I would lay it much flatter. You want the part that doesn’t print to be more perpendicular to the build platform. I’d make the angle between the “back” of the part and the face of the build plate something less than 30º so that the end that doesn’t print is more perpendicular.
