Print Clear / High Temp Resin to be Transparent
Hi,
I have a pretty big manifold part, 350ml, that I’m printing. I would like this part to be transparent on the top but flat on the bottom. I would like to see the fluid passing through inside the manifold. What I’ve notice for other pieces, printing without the support made the piece tranparrent. However for my current geometry I’m not sure if I can find a way to print it without supports. Does anyone have any suggestion on printing a clear print?
Hi! To reach transparency on prints, you might need to use additional post-processing steps like sanding or coating. You can find an overview in our guide to transparent 3D printing. Hope this helps!
Are you printing on F3 or F4? With MSLA (F4) a layer perpendicular to the build platform will be clear enough for visuals if you get clever with orientating. You can also use cup mitigation in the print settings editor to push the orientations you can print at. SLA you are just going to have to post-process.
If neither work, wet sanding is you friend. Start at 320 and step up to 1500-3k depending on the finish you want. Novus polishing compound is helpful as well. I’ve printed multiple Clear v5 parts to use for PIV successfully with some effort put into post-processing steps.
