PreForm "Fill Chamber" Bugs
Just wandering why now the “Fill Build Chamber” function in Preform is packing the chamber outside of its boundaries…making it pretty useless when you have to go back and bring parts within bounds of the chamber?
Its the little things like this and Formlabs failures in software development, firmware update failures, that make me very interested to see how the X1 does in the wild…
and “Distance to Wall” doesn’t seem to be doing anything
Those vertical lines correspond to the rounded corners, not to the wall planes. I see how that’s confusing from those angles. The tips of the top and bottom horizontal lines correspond to the walls, and it seems your models fit between them. I think it will be clearer if you check the top view.
