These images are a part printed on a Form 1+ using Photocentric3D Hard Clear resin on the Form 1+ Clear FLGPCL01 setting @ 0.1 layer thickness
The design is from the History channel series Vikings, they have some 3D printed props available to download It’s Rollo’s armband. I’ve also done a few Erlendur’s ring prints in castable which I plan to use a test casting pieces next week. Photo’s of that will follow at some point.
This is the only resin I’ve used apart from castable and it was a nightmare to remove from the build platform, I shattered the first one because it was really stuck to the platform. On the second one I snipped the model from its supports then removed the supports and base with the scraper.
When I get time I’ll polish this and remove the support marks then I might give it a coat of paint to see what it looks like. I didn’t pay much attention to scale before printing, it’s quite small, no way did that actor that plays Rollo wear one this size…
