I have a phantom images problem on my printed objects with my form3, the same object printed on my form 2 does not have these problems …
The logo and the text Cigalon and engraved in the thickness of the wall 3 times on the revolution of my cone
This phantom image appears 3 times too
that certainly looks like an optical effect.
For one, its MIRRORED… note the reversal of the N
The odd thing is that it kooks like you oriented the part vertically…
If this does not show up on the same part printed in grey or other opaque resin, then I’m betting the laser is being partially refracted when it hits the beveled edge of the previous layer of clear resin.
Only partially curing resin somewhere else in the tank, but that when the laser hits the affected resin a second time, it cures the rest of the way…
Either that, or something in the light box is reflective enough to be mirroring a portion of the light path.
Did you check to see if the resin has any partly congealed lumps in it?
