Peel routine after firmware update
Hi,
This is more a suggestion than a problem to be solved. I noticed that after a firmware update is finished and the printer reboots, it does a peel routine. There’s no warning (or not one I know of) that this will happen, and if the resin tank cover is in place, parts may break. I once had to cover in place but luckily nothing was broken.
Did a miss a warning? If not, I suggest adding one or removing the peel routine after reboot.
Br,
Markus
The Resin Tank cover shouldn’t be on while the tank is inside the printer. The orange cover is designed to block out reactive wavelengths so the resin will be protected from curing while inside the machine. I just tested this and while I don’t think having the cover in will cause damage, it does prevent a few movements like the wiper movement and is generally unnecessary.
