A small object I just printed had some areas with an orange peel texture (this texture was not in the file, not wanted).
It was not over the entire print, just a certain area. The part was printed using Tough resin. Any thoughts what might
have caused this? Thanks
A photo would help. Check the tank’s windows and printer’s glass to see if there is dirt, resin or fingerprints. You can also try to print the same part somewhere else and if the print is fine, there is definitely something in the way of the laser in a specific area on either the tank or the printer.
John means “print somewhere else” as in a different spot in the tray - not at a friends house or anything
