The bubbles work themselves out within 1/2 hour or so. I only had one instance where the silicone edges delaminated from the tank, and that was most likely due to the tank not being properly cleaned prior to the recoat.
I was having problems with the LT tanks and advised to change the elevation of the print platform as follows:
"on your Form 2, under “Z Fine Tuning.” To bring the build platform down, make sure you hit the minus button, so that the value displayed reads -0.5 mm. Once adjusted, you can try printing as normal. Your Form 2 will remember this setting for subsequent prints. "
It seems to have worked.
