I want more than 0,1 mm of acuraccy, more resolution, because for the internal part of the splint it seems no very smooth, i can see marks.
Thanks in advance.
Thanks in advance.
Hello @Taylor,
Thanks so much for taking the time to post!
I just want to be sure I understand your question. Currently, we don’t manufacture an LT Clear resin. Are you referring to our Dental LT resin? If so, the reason why the layer height options are pretty limited is that the resin is meant for a relatively limited use-case and we’ve determined .1mm is the best layer height for those uses.
Do you mind if I ask what kind of project you’re working on and what your goals are? If I know what you’re trying to accomplish I can recommend more specific tips for you moving forward.
Bite Splints, but hwen finished its ok, only a marks into the tooth side (the outside i can polish but the inside nope), when I mill a bite splint it finished smooth.
I want more resolution to avoid this marks.
Thanks.
