# Mixing resins to get charactersitics of both?
**URL:** <https://forum.formlabs.com/t/mixing-resins-to-get-charactersitics-of-both/24536>\
**Created:** [August 27, 2019, 6:48pm UTC](https://forum.formlabs.com/t/mixing-resins-to-get-charactersitics-of-both/24536 "2019-08-27T18:48:12Z")\
**Showing post:** 2
**Author:** ![Brandon\_A](https://avatars.discourse-cdn.com/v4/letter/b/74df32/32.png) [@Brandon\_A](https://forum.formlabs.com/u/Brandon_A)\
**Post date:** [August 27, 2019, 7:46pm UTC](https://forum.formlabs.com/t/mixing-resins-to-get-charactersitics-of-both/24536/2 "2019-08-27T19:46:19Z")
I think your logic makes sense, the tricky part is getting the curing intensity correct.
Check out this older thread exploring the same idea with the F1+
> [@A bit of resin alchemy](http://forum.formlabs.com/t/a-bit-of-resin-alchemy/6630):
> I’m making an object that snaps together (it’s classified, so I can’t post the pics unfortunately), and has very tight tolerences (it’s got to create an airtight seal with a gasket squished by the pressure of the snap-fit), and has to be easy to take apart and put together repeatedly. A tall order for printed materials. I’ve been hacking around, trying to get parts that are both very accurate, and also able to handle repeated snapping-unsnapping without fracturing. Clear by far produces the mos…
_[View the full topic](https://forum.formlabs.com/t/mixing-resins-to-get-charactersitics-of-both/24536)._
