Hi everyone,
I’m currently working on a project at Brazil focused on 3D-printed eyewear for children. To achieve the specific balance of translucency and mechanical resistance we need, we’ve been experimenting with custom resin blends using the Open Material Mode.
Specifically, we are testing:
Durable + High Temp (aiming for thermal resistance + flexibility)
Durable + Clear (aiming for impact resistance + high transparency)
While the material properties are looking great, we are hitting a wall regarding support optimization and surface finish. Since these blends change the viscosity and curing speed compared to the standard profiles, the supports are either too hard to remove or leaving significant marks on the frames.
Formlabs support (rightfully) cannot provide fine-tuning for custom settings, so I’m turning to this community.
Has anyone here experimented with similar blends (Durable mixes)?
Which “Base Profile” have you found most successful for hybrid resins?
Any tips on adjusting touchpoint size or density in PreForm when the resin is “stickier” than usual?
Our goal is a 2026 launch, and any insights on how to improve the surface quality of these custom mixtures would be incredibly helpful!
Thanks in advance!
