Anyone successfully repaired an LT vat with a broken holding tab? Formlabs support was of no help unfortunately. I originally tried to glue the original busted piece back on with epoxy; it busted off immediately on insertion. I have a number of other vats and none have done this. Would like to repair this unit because the surface is relatively pristine.
You need to drill small diameter holes and insert metal wires/pins to spread the forces, a good alternative to epoxy is the 5 seconds glue
https://www.amazon.com/Paddsun-Second-Plastic-Welding-Compound/dp/B078V45GYY/ref=pd_sbs_201_t_0/133-4014411-6809725?_encoding=UTF8&pd_rd_i=B078V45GYY&pd_rd_r=35fafd2c-541a-4cee-9e4a-5d0e6beec4ad&pd_rd_w=Y3FKr&pd_rd_wg=jrmpj&pf_rd_p=5cfcfe89-300f-47d2-b1ad-a4e27203a02a&pf_rd_r=ZQPF78VMRG81T0EC99K7&psc=1&refRID=ZQPF78VMRG81T0EC99K7
