Message on screen: Pleas remove obstructions from the build platform or resin tank and try again. The sweeper reaches the middle of the path and does not go any further and buzzes the motor and an inscription appears on the printer screen. Printer first time just started. What happens?
Did you previously have a print failure? Usually the wiper stops in the middle if there is a cured part stuck on the tank.
Even without a tray, when you bring a hand that mixer can only be brought to the middle, as if something hinders
That’s unusual. I suggest opening a support ticket.
Thank you, I’ll do it.
