Introduce a small shear movement with peel rotation
If you’ve ever tried to peel apart two microscope glass slides while there is a liquid is between them you’ll know that by introducing a small amount of shear as you peel them apart can make it easier to do so (sometimes).
Just wondering if this shear could be combined simply into the rotation movement such as by shaped location holes on the resin tank or does it already happen anyway with large surface areas just not controlled?
