How to level black metal plate supported by springs?
I got a resin spill and decided to clean the inside. I now realize that the black metal (above the optic plate) is supported by springs and I am guessing it is leveled somehow. How do I make sure it is leveled?
If you haven’t already, reach out to customer support.
The tray (black metal frame that the tank attaches to) is leveled at the factory. Customers should not remove the tray or adjust the leveling screws, otherwise the calibration will become invalid. If you have a resin spill you can clean around and under by using the edge of a paper towel, but the printer body doesn’t need to be perfectly clean to print well.
As Craig said, if you’ve already adjusted the leveling screws or have any other issue then Customer Support will be able to help you.
