The image attached is show the materials coming out when is printing of the 3D file.
Please advice how to fix it .
Thanks!
Remove the tray, wipe the spill with paper towels, avoid touching the bottom window of the tray. Don’t use IPA to clean the tray because it will degrade the acrylic.
If you have resin that has spilled on the window of the printer, then you’ll need to be very careful to clean it, I would contact Formlabs and get advice.
