# How safe is it to breath and touch the Isopropyl alcohol?
**URL:** <https://forum.formlabs.com/t/how-safe-is-it-to-breath-and-touch-the-isopropyl-alcohol/2313>\
**Created:** [October 17, 2014, 5:50pm UTC](https://forum.formlabs.com/t/how-safe-is-it-to-breath-and-touch-the-isopropyl-alcohol/2313 "2014-10-17T17:50:54Z")\
**Showing post:** 2
**Author:** ![Michael\_Braian](https://avatars.discourse-cdn.com/v4/letter/m/7cd45c/32.png) [@Michael\_Braian](https://forum.formlabs.com/u/Michael_Braian)\
**Post date:** [October 17, 2014, 8:09pm UTC](https://forum.formlabs.com/t/how-safe-is-it-to-breath-and-touch-the-isopropyl-alcohol/2313/2 "2014-10-17T20:09:02Z")
> [@IPA Alternatives](https://forum.formlabs.com/t/ipa-alternatives/2131/1):
> The recommendations are that IPA should not be closer than 50cm to any electronics, to have a ventilated area and the most obvious to use protective gloves.
The recommendations are that IPA should not be closer than 50cm to any electronics, to have a ventilated area and the most obvious to use protective gloves. If you are going to use a fan in order to remove the fumes from your room, the fan needs to be approved for flammable vapours.
_[View the full topic](https://forum.formlabs.com/t/how-safe-is-it-to-breath-and-touch-the-isopropyl-alcohol/2313)._
