How do you clean the build platform?
I’ve been using the alcohol squeeze bottle and rinsing off the metal platform and sides, wiping with a paper towel, then repeating.
So far I only have clear resin, but I plan to use the same platform for both clear and white resin. Is this process sufficient?
Shawn,
As long as you have made sure to remove all excess resin from the platform it should be fine to use when switching colors.
