Grey V4 Solvent Compatibility with soluble cutting oil?
We are needing to machine some of our Grey V4 printed parts in our CNC machine centres. They have a cutting oil/coolant specified for use with Brass (Quaker Houghton, CINDOL 305D). How can I determine if this has any affect on the mechanical properties of fully cured prints? It doesn’t seem to on a few we tried. This is not a long term issue as the parts are one off prototypes.
Thanks.
Hi @Andrew_W! In the technical data sheets of our materials, we list the compatibility with a few different solvents, stating the weight gain over 24 hours in percent. You can find the data sheets here. I hope this is a useful starting point!
