# Grey V4 foaming and pitting in final print
**URL:** <https://forum.formlabs.com/t/grey-v4-foaming-and-pitting-in-final-print/20739>\
**Category:** Form 2\
**Created:** [October 9, 2018, 9:35am UTC](https://forum.formlabs.com/t/grey-v4-foaming-and-pitting-in-final-print/20739 "2018-10-09T09:35:18Z")\
**Showing post:** 5
**Author:** ![DKirch](https://sea1.discourse-cdn.com/flex025/user_avatar/forum.formlabs.com/dkirch/32/20300_2.png) [@DKirch](https://forum.formlabs.com/u/DKirch)\
**Post date:** [October 17, 2018, 2:03pm UTC](https://forum.formlabs.com/t/grey-v4-foaming-and-pitting-in-final-print/20739/5 "2018-10-17T14:03:52Z")
Hey there!
Apologies for the late reply in this thread. I’m so sorry to hear you’ve been having some less than ideal print results recently.
I suspect most of these errors are related to that roughed up resin tank. That being said, 1 liter is significantly less resin than we’d expect to get through a normal tank that’s functioning properly.
If you get in touch with our support team at the link below we’d be happy to investigate what’s going on a little more closely, and I’m sure we can get that tank swapped out for you, as that’s not normal expected behavior.
> [@Screen "bad pixel line"](http://forum.formlabs.com/t/screen-bad-pixel-line/20770):
> this line was detectet before print couple days ago printer was rebooted and undplugged from ac, its not helps…any ideas? p.s. the firmware was updated a week ago, so preform to
Do you happen to have a fresh tank available to you at the moment, and if so, does that produce cleaner results?
_[View the full topic](https://forum.formlabs.com/t/grey-v4-foaming-and-pitting-in-final-print/20739)._
