We would like to use the Form 4 for research on spatial halftoning in photopolymerization. We will generate our own 1-bit binary PNG masks for each layer and need the printer to expose each layer according to these masks.
Could you please confirm the following?
- Is there a public API, research SDK, or collaboration program that supports importing custom per-layer exposure bitmaps without re-slicing an STL file?
- Can exposure time or light dose be set independently for each layer?
- Are the input patterns subject to scaling, anti-aliasing, boundary compensation, or any other processing? Can you provide documentation describing these operations and how to control them?
- What are the required bitmap dimensions, black/white polarity, coordinate orientation, and usable exposure area?
- If this workflow is supported, could you provide a minimal working example compatible with our firmware version, file format documentation, and details of any required licenses or permissions?
