# Gear surface deformation
**URL:** <https://forum.formlabs.com/t/gear-surface-deformation/1999>\
**Created:** [September 17, 2014, 7:27am UTC](https://forum.formlabs.com/t/gear-surface-deformation/1999 "2014-09-17T07:27:45Z")\
**Showing post:** 7
**Author:** ![JoshK](https://avatars.discourse-cdn.com/v4/letter/j/4da419/32.png) [@JoshK](https://forum.formlabs.com/u/JoshK)\
**Post date:** [September 17, 2014, 3:48pm UTC](https://forum.formlabs.com/t/gear-surface-deformation/1999/7 "2014-09-17T15:48:38Z")
I would probably stand it up to print, but you say that makes it oval? You can use this test file to calibrate X and Y, and then if it still stretches you use scale to control the Z (height). For example, if it is 1% too tall, you can scale the model down 1% then stretch X and Y both by 1% in the fine tuning tool to cancel the effects on those axis. If height is wrong by more than say .5mm I would contact support if it were me.
> [@Print Better by Discovering your Form1+ Advanced Calibrations](http://forum.formlabs.com/t/print-better-by-discovering-your-form1-advanced-calibrations/1852):
> You can get better prints by knowing about the errors in your Form1+. You can even print this at the same time as other models so you don’t have to do a special run. And if you post your results, we can discover what is typical is too. I made this test file for the community and just printed it: [https://www.dropbox.com/s/qbbuyuo4oxdqepv/Form1%2B%20Scale%20Test.form?dl=1](https://www.dropbox.com/s/qbbuyuo4oxdqepv/Form1%2B%20Scale%20Test.form?dl=1) (Form1+ Scale Test.form) And then measured it with a digital caliper. And from the various measurements I was able to dis…
_[View the full topic](https://forum.formlabs.com/t/gear-surface-deformation/1999)._
