# Fuse 1/Fuse 1+: “Distance to Wall” function
**URL:** <https://forum.formlabs.com/t/fuse-1-fuse-1-distance-to-wall-function/44091>\
**Category:** Feature Requests & Ideas\
**Created:** [April 9, 2025, 5:49am UTC](https://forum.formlabs.com/t/fuse-1-fuse-1-distance-to-wall-function/44091 "2025-04-09T05:49:48Z")\
**Showing post:** 6
**Author:** ![jmasterson](https://avatars.discourse-cdn.com/v4/letter/j/53a042/32.png) [@jmasterson](https://forum.formlabs.com/u/jmasterson)\
**Post date:** [April 30, 2025, 6:00pm UTC](https://forum.formlabs.com/t/fuse-1-fuse-1-distance-to-wall-function/44091/6 "2025-04-30T18:00:48Z")
Thanks for forwarding that feedback! Would you mind also sharing the following information from [this post](https://forum.formlabs.com/t/preform-model-spacing-for-manual-packing/44145) with the PreForm team?
> It would be really helpful if manual packing could still respect a minimum spacing setting. I can see two possible ways to support this:
> 1. Add a visual indicator that shows the set minimum spacing as a boundary around each model.
> 2. Update the “Overlapping Models” warning so it also triggers when models get closer than the specified spacing.
_[View the full topic](https://forum.formlabs.com/t/fuse-1-fuse-1-distance-to-wall-function/44091)._
