It would be great to get some sort of response that directly answers the question.
It’s especially frustrating because the studio 1 is compatible with the form 4 resins but the form 4 isn’t compatible the studio 1 resins.
As a Form 4L owner i don’t use my machine when i could because of the ridiculous cost of resins and then there is the insulting high price of 5000 USD for open material mode and to make matters worse the Tough 1500 V2 for the 1 is half the price of the same resin with the same properties as the 4L not to mention the outrageous cost for Resin Tanks. They are asking us to steer away from SLA in a cost driven environment. I could go on… I will not criticize the support staff because they are excellent, were it not for them i would have sold my entire 4L line.
It doesn’t have the exact same properties and the resin tanks are surprisingly cheap with Formlabs… Plus the resins are all competitive or cheaper than alternatives
I get ya though. Open Materials mode is way too expensive
It does have the same properties. Go compare the numbers in the datasheet.
WTF are you smoking? Only the Studio 1 Alpha resin prices are competitive
Maybe if you’re only making consumer products? These are commercial resins with commercial grade specs and the cheapest alternatives to any of the ones I need in order to do my work are exactly the same price as Formlabs resins. Most name brands for what I need are $30-50 more expensive
Well, you got me curious, so I went to go double check.
Turns out they don’t even have a separate datasheet for the Studio 1 version. Yet, it is incompatible with Form 4 printers, so it stands to reason that it is different somehow.
I don’t see how they even could have the same properties if one is literally incompatible with the other printer, but without an actual datasheet, which they have no real legal obligation to provide, we can’t really know. Unless of course you know something I don’t, which let’s be real, is very likely lol
I went through your post on Form 4B - Long-form review and learnt a bit about you and your business. Its great to see how you were able to grow your business with the 4L.
The biomed and dental resins industry might actually be expensive and Formlabs could be competitive in that segment, but not all of us are in the same field.
For a long time most non bio-medical users who used engineering grade resins from Formlabs also felt the price was justified as we were getting access to high spec resins but when the same company introduces essentially the same resin with same properties at the half price (We are not claiming this, Formlabs is) that view no longer stands.
What’s more damaging is that when the same company produces GP resins for the new printer which are cheaper and better than already existing GP resins for the older printer and lock the older users out without a clear technical explanation.
Right? that’s what has got me confused. The studio 1 is compatible with almost all the resins the form 4 is compatible with but the reverse isn’t true?
Compatible: Automatic dispensing from cartridges is enabled, but the user will be responsible for settings tuning. Formlabs may provide a starter setting on the Forum for some materials.
Right - I think I am just saying that I don’t believe Formlabs when they say these have the same spec OR when they say they are incompatible on the Form 4. I don’t think those can be true at the same time, so I’d like some clarification from them.
Personally, I don’t know which one I’d rather be true but either will reflect bad on them. If they’re both true, then I just gotta know why. The whole sitch stinks to me
@dogichow any update on any of the questions in this thread?
Since there’s no separate Studio 1 datasheet, I wouldn’t assume the two Tough 1500 V2 variants are identical just because the names match. “Incompatible” may simply mean no validated Form 4 print profile or cartridge/chip recognition, rather than a chemistry difference. It would be worth asking Formlabs specifically whether the Studio 1 cartridge physically fits a Form 4 and whether Open Mode/custom settings are allowed. That answer would distinguish a real hardware constraint from a validation or marketing lock.
The confusion is not because the name is same, ALL MECHANICAL PROPERTIES provided on the materials page match exactly for both resins, check the images below-
Validated profile is controlled by Formlabs, unless there is a scientific reason for incompatibility, its their business prerogative if they want to provide it or not so not having a validated profile cannot be a reason.
Flexible 80A V2 has a validated profile for both Form 4 and Studio 1 and can be bought by both users so it is granted that the bottle design is the same, This also means that there would be no problem with chip/cartridge recognition.
Also this is on the official page for Alpha Resin (Model), similar information is provided for all Alpha Resins.
This very clearly says that the Alpha resins require Open Material Mode for Form 4.
TL;DR - Right now there is no clear, scientific evidence as to why Alpha Resins or Tough 1500 Resin are locked for Form 4 users.
