Form 3 Unboxing and First Impressions!
#69
Obviously the definitive test will be the print of the same subject with the F2 vs. F3.
#70
We will be doing this I believe today. I will let you know the results as soon as we find out.
#71
Pictures please if possible. Been dying for some actual Form 3 eye candy. Everybody seems to be posting words if anything which is few and far between lol.
#72
Reading the praise :raised_hands:
from your test drive :red_car:
I’m counting the days :date:
'till mine’ll arrive :truck:
Thanks for the squint :eyes:
at your Form 3 :gift:
meantime I’ll print :gear:
vicariously :neutral_face:
#73
Mark,
Any update or pictures of first prints? or are you still waiting to use your form 3 … 21 days later?
#74
Here are some comparison pics of a pretty small part, roughly 0.3" diameter part. Form 2 print is always on left and Form 3 on right. White V4, 100 micron layer height. Form 2 used the orange regular resin tank and is about 2 years old. Sorry my pictures suck.
  1. Letters on raft are much more detailed and crisp on the Form 3. This should be an indication of better features throughout but maybe just the base layers, maybe because of lower compression force during layers.
  2. The support contact points end up being much smaller even though I used the same contacts and contact points for both prints (same preform file just changed printer). Preform recalculates supports but the points remain the same. This is the biggest difference I can see.
  3. There are some circular features that are hard to see in pictures that are more true to CAD on Form 3 than Form 2.
  4. The drain holes on the rafts did not print on the Form 2 but did print on the Form 3.
#75
Hi all,
Sorry for the delay in updates!
Here are a few pictures and I added some close up comparisons of clear in my original post so scroll up and take a look!
The sphere is about 30cm in diameter and was printed with 50um layers which is a layer height that is still currently in beta. We thought this piece was interesting because you can see very small layer lines and you can also see very small lines that appear to be caused by the stepping of the laser carriage. This part was unfinished and uncured at the time. There appears to be some extra material cured around the support marks which is very common on the Form 2. A very small amount of sanding and polishing had this part looking perfect!
This next piece is very small as evidenced by the supports. It looks great in person and this picture was taken under the inspection scope at about 30x magnification.
So far, the Form 3 has been running great! We have had some trouble removing parts from the platform and a few software glitches but we have been very pleased with the results.
It is also worth noting that the Form 3 is very quiet in operation and the light at the top of the machine is very useful. It glows white during normal printing and flashes to get your attention when it is not happy:)
More to come.
Mark
#76
Absolutely love this, thank you for the photos. It’s odd that review units weren’t sent out earlier or something to give people time to hype the machine upon launch. I watched DJI launch their new FPV system yesterday and immediately there were tons of reviews, photos, opinions, etc. from a lot of people who were given review units. Formlabs! You have an amazing product, the word needs to be spread more. Again thanks for sharing especially about the light … that’s 100% new information to me, look forward to future posts.
#77
@gjgomes, were you on the “designated field tester” list?
I ordered mine on April 4th and I received a Clay Siegert email now stating mine won’t arrive until Sept 6th.
#78
Hi Mark
Love the detail nice and sharp. What is the distance between the stepped features on your printed model under 30x mag?. The clarity is impressive also
#79
I would like Formlabs to chime in on “open mode” on the F3…?
#80
@da40flyer, I suppose I can expect to get a similar email from Formlabs next week. Kind of interesting that none of the 3 different printers currently offered by Formlabs are shipping…
#81
Hey there!
Open Mode is absolutely coming but nothing to talk about at this time. More details coming soon. :slight_smile:
Form 3 Resin Availability Update
#82
Thats good to know - any idea of how long before its likely to be implemented?
#83
That’s good to know. Does “similar in scope” mean that Castable Wax will not be available as print profile, as seen in How open is open mode on Form 2??
#84
Do the contact points look identical when you view them in the slicer? Do you think the tips are smaller because the support structures are printed “more accurately”, or do you think there’s some software/firmware trick going on?
Ah, I was concerned about artifacts stepping might produce. I assume those are the less dense lines seen on the sphere, perpendicular to the layer lines. Hard to tell, but it looks like the shifting isn’t exactly uniform - is that correct? Does it occur on other layer heights as well (or to varying degrees)? The lines look pretty feint - any estimate on how proud the “worst case” steps are?
That’s another question I posed before buying. Could you elaborate on your experience so far removing failed prints? Is it tough to do without damaging the flexible membrane? Is the software patch to union failure areas out yet (or do you think it will help when it is)?
#85
The supports look the same in Preform. I don’t want to speculate too much on why they came out smaller until I have more experience with the printer.
#86
We have done a small comparison video from the Form2 to the Form3 if you want to check it out here.
#87
Good demo but comes across like the same videos Formlabs puts out to sell the form 3 product & not a actual end user review. I follow this discussion for REAL end users reviews of the form 3.
#88
Not even seeing many write ups… much less videos? Why is everyone too quiet?
